Author Topic: 12301: Issues with Configure | Manage Technology  (Read 6174 times)
« on: July 07, 2016, 05:51:06 pm »
Is anybody else seeing this anomalous behaviour?
As I 've mentioned elsewhere, we (currently) maintain our MDG manually.  We often make many incremental changes while we're developing/validating new functionality.
So the process is, create new version of MDG, switch to EA, doable MDG, reenable MDG,, check result.  This can happen several times in only a few minutes.
Under 12.1, there was a problem that the diagram (and toolbar) you were in would not update correctly following the doable and  reenable, but there was a work around.
Under 1301, Sparx have conveniently done a better refresh after the disable and reenable.  8)   However the checkboxes in the Extensions dialog are misbehaving. :(  After the first time through, the check box for the MDG doesn't work properly.   Sometimes the only way to restore it is to disable and reenable another MDG (at the same time).
TIA,
