Author Topic: How to update information flow connectors  (Read 4531 times)
anderst
« on: October 08, 2009, 03:03:29 am »
 I'm would like to create a script that updates the type of information that flows for all information flow connectors in a diagram.
The script would look like this:
var diagram as EA.Diagram;
diagram = Repository.GetTreeSelectedObject();
for ( var i = 0 ; i < diagram.DiagramLinks.Count ; i++ )
    var link as EA.DiagramLink;
    var c as EA.Connector;
    link = diagram.DiagramLinks.GetAt(i);
    c = Repository.GetConnectorByID(link.ConnectorID);
    if (c.Type == "InformationFlow")
        // code to update information item conveyed goes here
        c.Update();
The question i have is how to update information item conveyed?
 I cant find anything on the connector or the link, where is this stored?
Repository.ReloadDiagram(diagram.DiagramID);
« Last Edit: October 08, 2009, 06:50:50 pm by anderst »
David OD
Re: How to update information flow connectors
« Reply #1 on: July 14, 2010, 05:33:36 pm »
Bump.
I also need to be able to find this data, as I am trying to generate documentation based upon these Information Flows.  How do we locate the class that is linked to the Information Flow connector?
Regards
« Reply #2 on: July 14, 2010, 05:36:22 pm »
Have you looked in the database?
There might be some kind of id in one of the pdata columns that points to the informationItem element.
David OD
SOLVED: How to update information flow connectors
« Reply #3 on: July 16, 2010, 11:34:23 am »
Thanks Geert.
After much playing around I discovered a way of obtaining the information by doing a SQL query against the database.  The data is held in the table t_xref, but doesn't appear to have been surfaced anywhere in the API that I can see.
The following code may assist others:
' Get class linked to information flow
Public Function getConveyedClasses(connectorGUID As String) As String
    Dim sqlText As String
    If connectorGUID = "" Then
        getConveyedClasses = ""
        Exit Function
    End If
    sqlText = sqlText & "Select Description "
    sqlText = sqlText & "FROM t_xref "
    sqlText = sqlText & "WHERE client = " & connectorGUID
    sqlText = sqlText & " AND type = 'connector property' "
    sqlText = sqlText & " AND behavior = 'conveyed' "
    getConveyedClasses = SQLQuery(sqlText)
End Function
Note that when given the GUID of the connector, this returns an XML string with the GUID of the class being conveyed by the flow.
I called this function as follows:
If conn.Type = "InformationFlow" Then
   sqlData = EAR_Connection.getConveyedClasses(conn.connectorGUID)
   startGUID = InStr(sqlData, "{")
   endGUID = InStr(sqlData, "}")
   elementGUID = Mid(sqlData, startGUID, endGUID - startGUID + 1)
   workText = EAR_Connection.getElementNameByGUID(elementGUID)
End If
This does what I need it to do, but could no doubt be improved/expanded depending upon other's needs.
I hope it helps.
« Last Edit: July 16, 2010, 11:35:17 am by david.odriscoll »
Regards
