Author Topic: Modelview for not validated requirements  (Read 4445 times)
jepessen
« on: July 09, 2016, 10:42:34 pm »
I've many requirements in many packages.
I want to obtain a list of these requirements that are not validated or not implemented.
I've added in a diagram a Modelview artifact, and I've used following query:
SELECT t_object.Name FROM t_object WHERE t_object.Status <> 'Validated';
I obtain all elements in my project that are not validated. How can I select only requirements (both functional and non-functional)?
Re: Modelview for not validated requirements
« Reply #1 on: July 10, 2016, 12:27:51 am »
WHERE Object_Type='Requirement' AND (Stereotype='Functional' OR Stereotype='')since (EAUI) functional stereotyped requirements come with empty stereo. Once changed you can not alter alter with the properties dialog (just ignored; report a bug who ever wants).  Using the View/Properties dialog allows to alter it. Then the stereotype is set to Functional -  argh
Respectively:
WHERE Object_Type='Requirement' AND (Stereotype='Display')for a Display stereotyped requirement.
jepessen
« Reply #2 on: July 10, 2016, 04:59:12 am »
Thanks a lot, this is what I needed.
