Author Topic: Linking to Virtualised End Points  (Read 8193 times)
Screwtape
« on: July 12, 2016, 08:50:03 pm »
Hi Folks!
I'm trying to draw a class diagram that represents the data required in a query. I thought using virtualised end-points would help show the structure, but it doesn't.
I'm looking to do something like:
A--B--C--B--B--D
So I virtualised the B following C, but I cannot link anything to the virtualised end.
Is there any way to link to the virtualised end-point, or can anyone suggest a better way of representing a table multiply linked in a query structure.
Thanks for your help.
Screwtape
Re: Linking to Virtualised End Points
« Reply #1 on: July 12, 2016, 10:05:06 pm »
Draw as many associations as needed. B connects to A, C (twice), D and self. A to B, C twice to B, and D to B. You could name the association in the order you need them.
As you do that for a query, you will probably use instances. In that case just use multiple instances and you're also done.
« Reply #2 on: July 13, 2016, 09:41:34 am »
Virtualised End Points aren't real - that's why they are virtualised.   ;)
You get one per real relation (and only when the line type is correct - see my (fairly) recent posts on virtualised End Points to get a better understanding).
