Author Topic: 1303 - Dialogs open partially off-screen.  (Read 9926 times)
jwestbrook
« on: July 31, 2016, 02:01:48 am »
I had this issue with certain pop-up dialogs in v12 but I'm seeing it with most pop-up dialogs in v13. The dialog box opens partially above the top of the screen. The part of the dialog that is off-screen is the ribbon at the top that I would need to click on in order to move the box, thus, I can't move the box. For certain dialogs (e.g. model mail messages) there is no way to close the dialog because the "close" button is off-screen. This happens regardless of the size and placement of the EA application itself. Regardless of which monitor I run the application on, the dialogs always open on the primary monitor and always partially off-screen. Has anyone else seen this behavior and if so, have you figured out a way to fix it?
Examples of the dialogs I'm talking about include "clone diagram as new"  and "add-->diagram".
EA 1303 (but I've seen similar behavior with 12)
Windows 8.1 (but I've seen similar behavior with 8.0 and 7)
VKN
Re: 1303 - Dialogs open partially off-screen.
« Reply #1 on: August 01, 2016, 09:35:33 am »
Changing the workspace may fix it.
« Reply #2 on: August 02, 2016, 02:46:43 pm »
I too have been having this problem a lot.
In my situation this occurs as I move a portable device between work stations (and the number of monitors varies).
I did put in a feature request,
and also received the useful advice to select the dialogue box (assuming you can see a bit of it) and then use
ALT+SPACE providing access to the system menu and thus you can move the window. Enjoy
« Reply #3 on: August 02, 2016, 08:03:36 pm »
I knew about the alt-space but could not remember the key combination. Hope, this time it sticks...
