Author Topic: Search mechanism  (Read 5267 times)
ahafez
Search mechanism
« on: August 01, 2016, 09:27:58 pm »
Is there is an EA API could be used in a script for searching?
I am looking for an API that its inputs the type of the search element and part of its name, and the output is a list of matching elements like the GUI search using the (Crt+f).
What I don't like by go though all the element from the root and check its type and name but if so is there is an example of that way?
Ahmed
Re: Search mechanism
« Reply #1 on: August 01, 2016, 09:52:04 pm »
Actually you can do that completely without scripting by using the embedded SQL search. Ctrl-F, click the "new search" icon top right (right of the green triangle), name it and choose SQL Editor. Here you can create any kind of search.
ahafez
« Reply #2 on: August 01, 2016, 11:37:13 pm »
Hi qwerty,
Thanks you for your reply.
I found the GetElementsByQuery() API and it works well with me.
