Author Topic: Missing Header & Footer in generated file  (Read 6457 times)
Pawel Zubkiewicz
    • zubkiewicz.com
« on: August 02, 2016, 12:33:17 am »
Hi All,
Once again I stumbled upon a problem.
I wrote a script that generates RTF document, everything works great except one detail: Header & Footer are missing in generated file.
I have them templates (logo and page number) but they are not present in generated file.
Basically my  script is invoked from context menu on diagram OnDiagramScript(); listener function.
Then I get list of all elements on diagram and generate the file
more or less like that:
            var docGenerator = Repository.CreateDocumentGenerator();
            if (docGenerator.NewDocument("")) {
                documentCoverPage(docGenerator, elements);
                docGenerator.InsertBreak(0);
                docGenerator.InsertTableOfContents();
                docGenerator.SaveDocument(FILENAME, DocxType);
                Session.Prompt("Document successfully generated", promptOK);
Where
            documentCoverPage = function (docGenerator, elements) {
            docGenerator.DocumentPackage(packageId, 0,TEMPLATE_COVER_PAGE);
            var documentChanges = filterElements(elements, "Change");
            for (var i = 0; i < documentChanges.length; i++) {
                var change = documentChanges[i];
                docGenerator.DocumentElement(change.ElementID, 0, TEMPLATE_CHANGE_HISTORY);
Generaly I don't do anything special.. the only difference is that everything is started and generated in script, not from F8 / Generate Documentation functionality.
Did you guys have problems like that?
Any idea on how to fix it will be appreciated :-)
Enhanced Requirement Attributes Addin for Enterprise Architect (ERA Addin) - http://zubkiewicz.com/?p=239
Dermot
Re: Missing Header & Footer in generated file
« Reply #1 on: August 02, 2016, 12:16:02 pm »
Pawel Zubkiewicz
    • zubkiewicz.com
« Reply #2 on: August 02, 2016, 06:09:42 pm »
Thanks Dermot :-)
It works !!!
It also works for EA12.1.
I just wonder why DocumentGenerator.InsertTemplate (string templateName) method does not have the same magical power to insert header and footer.
Now I need to have additional element just to have linked document with header and footer.
But I know... it's EA way  ;D
