Author Topic: Custom Template based C Code Generation  (Read 3570 times)
manish_kumar4all
« on: August 08, 2016, 07:29:23 pm »
I am trying to build a custom template for C Code Generation, for this I have defined a class and its respective Tag values through MDG Technologies toolbox I am going to configure the values (Tag value window) for the class.
Problem:
1. How to generate the code for Package which is having n-number of classes (If I select package and generate code, it should generate single .c & .h file for all classes present under that package)??
     --> I have tried to set “Filename” of all classes in same location but in this case last class were present in .h file
2. How to generate C code for composite diagram ?
      --> I am trying to generate the C code for composite classes but its generating as blank.
Thanks in Advance.
Manish
