Author Topic: Stereotype Profile Helper Tagged Values Grouping does not work!  (Read 6199 times)
PeterHeintz
When you define Tagged Values for Stereotypes with Profile Helpers and you add e.g. two Tag Groups, you can move the tags to those groups.
After closing and opening the Profile helper, tags defined e.g. under group A are now moved by EA under group B.
This behavior is in V12-V13.
Best regards,
Peter Heintz
PeterHeintz
Re: Stereotype Profile Helper Tagged Values Grouping does not work!
« Reply #1 on: August 11, 2016, 10:36:50 pm »
Just realized that this happens because of my tags in the different groups have same name (same name->reason why I grouped).
Root problem I think is that _tagGroupings just contain name of tags and cannot distinguish tags with same name.
Best regards,
Peter Heintz
« Reply #2 on: August 15, 2016, 09:26:21 am »
That's correct, the grouping isn't intended to provide any additional namespace. All tags within a stereotype should have a unique name.
