Author Topic: Close Tabs opened by LayoutDiagramEx  (Read 3971 times)
Bencrush
« on: August 09, 2010, 07:08:44 pm »
Hi
i am using LayoutDiagramEx in my Addin to layout my diagrams. But this method opens a new tab for every diagram. My problem is, that there are serveral hundreds of diagrams to layout and EA always crashes, because of too many tabs.
Is there a way to directly close or even just not open a new a tab when layouting an diagram?
Thank you very much :)
Re: Close Tabs opened by LayoutDiagramEx
« Reply #1 on: August 09, 2010, 07:27:47 pm »
Ben,
You could try to set Repository.EnableUIUpdates to false, and if that doesn't work close the diagram after layouting it by Repository.CloseDiagram (long DiagramID)
« Reply #2 on: August 09, 2010, 07:36:18 pm »
Hi Ben?
I had the same problem...  Basically, you need to keep track of open and closed diagrams yourself.
If you are explicitly opening the diagrams with your Add-In, you need to close it yourself.
I think there was some discussion recently on how to detect if a diagram is already open (without resorting to using broadcast events).
Bencrush
« Reply #3 on: August 09, 2010, 07:43:41 pm »
Thank you for your fast replies :)
I tried Repository.CloseDiagram (long DiagramID) as Geert said and it worked perfect. I guess I was blind, not finding it in the User Guide.
Ben
