Author Topic: MDA transformation - how set the value of a string  (Read 3095 times)
Thomas_Arnbjerg
« on: August 11, 2010, 07:31:35 pm »
Hi all,
How do you set the value of a string member from a MDA script when the quote is a reserved character?
The fragment below describes a constructor in C++ with relevant initialization (which will fail since quotes are illegal) where the member 'name' should be initialized with the model attribute 'className':
Operation
            name=%qt%%className%%qt%
            Tag
                  name="initializer"
                  value=%qt%name("%className%")%qt%
Thomas_Arnbjerg
Re: MDA transformation - how set the value of a st
« Reply #1 on: August 11, 2010, 11:19:56 pm »
Found a temporary solution using macros - i.e. the MDA transformation uses the member as an argument to a macro. The macro then 'stringifies' the argument:
#define QUOTE(x) #x
Not the best solution and a more proper one is still wanted..
