Author Topic: Code Generation Example?  (Read 5187 times)
Adrian.
« on: August 17, 2010, 12:45:00 am »
We are playing with EA and code generation at the moment.
Generating code (C) for classes and groups of classes is no problem; also, generating code for a state machine works fine.
What we now are not able to do is to generate a more complex code, for example in which several classes are involved in a sequence or activity diagram... we generated some pieces, but the function calls do not turn out right (at least it seems to us)!
So, is there an example project somewhere we could download and test for understanding? Anything involving several behaviour diagrams would be perfect!
Re: Code Generation Example?
« Reply #1 on: August 18, 2010, 03:15:19 pm »
Have you tried the example model that comes with EA?
Adrian.
« Reply #2 on: August 18, 2010, 03:28:22 pm »
Yes, I looked at the examples, but I could not find a behavior example models for code generation.
Nizam Mohamed
« Reply #3 on: August 18, 2010, 03:42:54 pm »
If you are looking for examples to illustrate code generation from behavioral models, please refer to the models at "Project Models.Systems Engineering Model.Implementation Model.Software" in the supplied EAExample.eap file.
