Author Topic: delete Connector does not work anymore  (Read 4465 times)
stao
« on: May 18, 2010, 11:36:26 pm »
I just upgraded to the newest EA version
and now my deleteConnector method doesnt work anymore.
public void deleteConnector(EA.Connector con, EA.Repository Repository)
            EA.Element client = Repository.GetElementByID(con.ClientID);
            EA.Element supplier = Repository.GetElementByID(con.SupplierID);
            short i =0;
            foreach(EA.Connector actLink in client.Connectors) {
                if (actLink.ConnectorID == con.ConnectorID)
                    client.Connectors.Delete(i);
                i++;
I tried all kind of update() and refresh on every involved object.
but the connection is still there.
Any Ideas
in EA 7.5 this method worked.
Stao
Re: delete Connector does not work anymore
« Reply #1 on: May 18, 2010, 11:52:56 pm »
Have you tried deleteAt()?
stao
« Reply #2 on: May 19, 2010, 12:12:00 am »
does not work.
it seems that the delete methods have no effect at all.
« Reply #3 on: May 19, 2010, 03:26:50 pm »
Have you reported it to Sparx support?
If this is a bug then they better fix it quickly.
stao
« Reply #4 on: September 07, 2010, 09:58:36 pm »
is there any solution?
im still not able to delete connectors via addin
beginner
« Reply #5 on: September 07, 2010, 11:21:26 pm »
I just tried it here. Works without problems.
Try to extract GetLastError() from the collection.
b.
« Last Edit: September 07, 2010, 11:24:15 pm by beginner »
stao
« Reply #6 on: September 08, 2010, 10:39:04 pm »
solved...
reload diagram != refreshAllOpenDiagrams
