Author Topic: Shape for port!  (Read 5750 times)
harvinder
Shape for port!
« on: August 02, 2010, 03:02:39 pm »
I am creating a uml profile in which I am trying to customize port stereotype.
The script used is as below,
shape main
    setfillcolor(255,0,0); // (R,G,B)
    startpath(); // Start to trace out a path
    moveto(0,0);
    lineto(0,40);
    lineto(20,30);
    lineto(40,40);
    lineto(40,0);
    lineto(0,0);
    endpath();  // End tracing out a path
        // Fill the traced path with the fill color
    fillandstrokepath();
    return;
When I attach this stereotype object to a class, the size is coming properly, however when I select the shape, selected area is shown bigger than the shape.
Any idea on how to solve this problem?
thanks
harvinder
Re: Shape for port!
« Reply #1 on: August 02, 2010, 03:31:58 pm »
Hi Harvinder,
If you are saying that even after your shape script is applied the selected size is still the original 100% size, then I don't think there's a solution.
There is no direct relationship between the shape you create with the shape script and the selection size of the element.  It would need a specific Shapescript method (such as SetSelectionShape()  or some such) to specifically set it.  There is no such method available.
Re: Shape for port!
« Reply #2 on: August 02, 2010, 03:37:26 pm »
The numbers in the moveto() and lineto() commands are percentages, not pixels, so drawing to the bottom right corner of your shape should be lineto(100,100); not lineto(40,40); and other commands will also need to change. If you want your port to display as 40x40 pixels, then you will need to use the command defsize(40,40);
harvinder
Re: Shape for port!
« Reply #3 on: August 02, 2010, 03:44:52 pm »
I made following changes in script
shape main
    fixedAspectRatio= "true";
    dockable = "standard";
    scalable = false;
    defSize(100,100);
    setfillcolor(255,200,0); // (R,G,B)
    rectangle(0,0,20,20);
    return;
and then changed the generated xml (uml profile)
Previously
           <Stereotype name="TestNet Input" notes="The input port" cx="90" cy="70" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
to
           <Stereotype name="TestNet Input" notes="The input port" cx="20" cy="20" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
and it is showing up properly
Question, what determines cx and cy? Only when did I set cx=20 and cy=20 does it show properly
Re: Shape for port!
« Reply #4 on: August 02, 2010, 03:56:49 pm »
Search the help for _sizeX and _sizeY
RoyC
  • Read The Help!
« Last Edit: August 02, 2010, 04:21:59 pm by RoyC »
Best Regards, Roy
harvinder
Re: Shape for port!
« Reply #6 on: August 02, 2010, 04:19:56 pm »
thanks guys, I am able to get the desired results now.
One more query, I have this stereotype <<TestNet Input>> port1 showing up, how may I customize it to just display say Input1
thanks
harvinder
Jim Beck
Re: Shape for port!
« Reply #7 on: September 09, 2010, 04:24:07 am »
Harvinder, would you please re-post your final shape script.  We are having this same problem.  I am about to submit a bug report if I cannot find an answer.
Also, your shape script does not have quotes around all values.  I wonder if the "false" without quotes is effective.
Thank you!  Jim.
