Author Topic: MDG's SysML Add-In  (Read 4982 times)
wschalch
MDG's SysML Add-In
« on: August 24, 2010, 04:23:29 am »
Before I was using ARTISAN Studio for SysML modeling, but since we use EA for software developments, I've decided to start using MDG's Add-In for SysML compliance. What I've noticed is that this Add-In is not SysML compliant. I have version 1.0. Is there any other version, which is SysML compliant?
Best regards,
Wagner
Ignacio G. T.
Re: MDG's SysML Add-In
« Reply #1 on: September 15, 2010, 10:13:30 pm »
I'm using EA Systems Engineering Edition (which implements SysML 1.1 internally, no with add-ins) and it seems rather SysML compliant.
philchudley
« Reply #2 on: September 17, 2010, 06:35:24 pm »
EA's built in SysML 1.1 is more or less SysML compliant. I use it occasionally, but I have noticed that you cannot display a Parts compartment within a Block element for example (you can in the MDG SysML 1.0 version)
There are other similar compartments defined in the SysML which again are not supported by Sparx
Because a Requirement element is already in EA, SysML uses the same element and hence its appearance differs from that defined in SysML.
Apart from this minor niggles, I find the SysML 1.1 works just fine. (The simulation of then parametric diagrams is a little limited however)
Cheers
Phil
Models are great!
