Author Topic: Access profile data from AI  (Read 7840 times)
rvaldes
« on: July 27, 2010, 06:14:03 pm »
Hi, im trying to access stereotype info from a profile that is packed inside a MDG Technology file that is deployed from an Addin.
I have checked that the stereotypes defined in my profile are not accesible from Repository class, since the Stereotypes collection of that class returns only the stereotypes stored in the .eap file.
Any workaround for this scenario?
Thanks in advance
Re: Access profile data from AI
« Reply #1 on: July 27, 2010, 07:14:36 pm »
If I understand you correctly, you'd like to access/manipulate the stereotype attributes - such as Fill colour.
This, as far as I know, is NOT possible.
Please submit a Feature Request and tell us the name,
leaving a note here to say you've done it.
We users can then vote for it using a Feature Request with the same name[/color]
Michael Proske
« Reply #2 on: July 27, 2010, 11:53:54 pm »
Try to read the profile data with an xml reader from the technology file. You have to write your own addin to get access. I used these to have update my own profile data with new tagged values. if you like i can send you the c# code.
mq-EA
« Reply #3 on: September 14, 2010, 03:40:12 pm »
How I can get available list of MDG Technology?
I fund methods:
- ActivateTechnology (string Name)
- DeleteTechnology (string ID)
- GetTechnologyVersion (string ID)
- ImportTechnology (string Technology)
- IsTechnologyEnabled (string ID)
etc. but where is information about  the technology ID?
« Reply #4 on: September 14, 2010, 03:52:12 pm »
Have you tried to use the "id" attribute in the xml files in C:\Program Files\Sparx Systems\EA\MDGTechnologies ?
mq-EA
« Reply #5 on: September 14, 2010, 06:19:18 pm »
Yes, this is it, but I want to have list of technologies from EA.
beggars can't be choosers :)
fwoolz
« Reply #6 on: September 15, 2010, 02:11:00 am »
Not sure if this helps, but...
EA stores imported profiles in table t_trxtypes, with the profile XML stored in the Notes (memo) field (BTW, MDA transformations, auto-counters and HTML styles are stored here as well). If the profile is imported and the original XML file isn't available, the XML can be gotten from this table.
Cheers,
Fred
Fred Woolsey
Interfleet Technology Inc.
mq-EA
« Reply #7 on: September 15, 2010, 07:16:30 pm »
I need something like that...
I activated technology in my repository and when I call select * from t_trxtypes in Model Search the result is an empty table ... Why .. ? :)
« Last Edit: September 16, 2010, 05:36:04 pm by mq-EA »
Michael Proske
« Reply #8 on: September 17, 2010, 11:19:22 pm »
I think it is not possible the select active technologies from a database because technologies are independent from a specific eap or database file. I think the only way to find out is to write a plugin and react on the Technology events like EA_OnPreActivateTechnology. From that point on you can load the profile data.
The following code just gives a hint how to load in the file
        public void open()
            //  XmlTextReader m_handle = new XmlTextReader(m_technology);
            m_xmlDoc = new XmlDocument();
            m_xmlDoc.Load(m_technologyName);
            m_stereotypeList = new List<Stereotype>();
            XmlElement root = m_xmlDoc.DocumentElement;
            XmlNodeList profiles = m_xmlDoc.SelectNodes("//UMLProfiles/UMLProfile/Documentation");
            foreach (XmlNode profile in profiles)
                XmlNodeList stereotypes = profile.SelectNodes("../Content/Stereotypes/Stereotype");
                //Select Stereotype attribute
                foreach (XmlNode stereotype in stereotypes)
                    XmlNode apply = stereotype.SelectSingleNode("./AppliesTo/Apply");
                    if ((apply != null) && apply.Attributes.GetNamedItem("type").Value == "ToolboxPage") continue;
                    Stereotype st = new Stereotype();
                    st.Technology = profile.Attributes.GetNamedItem("name").Value;
                    st.Name = stereotype.Attributes.GetNamedItem("name").Value;
                    if (apply != null) st.Apply = apply.Attributes.GetNamedItem("type").Value;
                    try
                        st.Generalize = stereotype.Attributes.GetNamedItem("generalizes").Value;
                    catch { }
                    XmlNodeList taggedValues = stereotype.SelectNodes(".//TaggedValues/Tag");
                    foreach (XmlNode tag in taggedValues)
                        st.taggedValues.Add(tag.Attributes.GetNamedItem("name").Value);
                    m_stereotypeList.Add(st);
I will create a plugin project and post it here in the forum so you can play a little bit with the functinality
Michael
