Author Topic: Import an external image on a EA.diagram  (Read 4774 times)
ALL_IN_ONE
« on: September 23, 2010, 07:33:27 pm »
Hello folks,
I need a solution to add external image on the diagram.
I tried it with some work around, its not a solution but got to know some insights.
EA.DiagramObject boundObj = (EA.DiagramObject)dia.DiagramObjects.AddNew("", "");
boundObj.ElementID = ele.ElementID;
boundObj.Style = "DUID=B9DE8FF2;ImageID=191;";
boundObj.Update();
dia.DiagramObjects.Refresh();
If you notice in the above code snippet, the diagram object style is hard coded because I know the image Id. Those external Image IDs you can see it in Settings-->Images and then unhide the third column which has the Image ID of the external diagrams (Not UML Diagrams).
Hence Does any body know how to embed image on a EA Diagram ?
regards,
ALL_IN_ONE
ALL_IN_ONE
Re: Import an external image on a EA.diagram
« Reply #1 on: September 23, 2010, 11:16:26 pm »
Hello all,
Can Any body provide some solutions to this issue? it is urgent?
@EA admin  : I am a registered user of EA, and I have not recieved any reply till now?
regards,
ALL_IN_ONE
smendonc
  • I love YaBB 1 Gold!
« Reply #2 on: September 24, 2010, 05:42:36 am »
You may want to contact Sparx support directly.  This is a user forum so there is no guarantee that you will get answers.
« Reply #3 on: September 24, 2010, 03:09:41 pm »
ALL_IN_ONE,
I don't know the answer to your specific question, but I can tell you how I would try to find out:
- Start with an empty model
- Create the diagram and embedded image through the GUI
- Open the database and inspect what has been added by EA.
- Try to recreate the same result using the API.
If at all possible, running a trace on the database may seriously simplify the "inspect what has been added" part.
