Author Topic: Serialize Repository using C#  (Read 6950 times)
jafuentes
« on: October 26, 2010, 02:50:33 am »
I´ve following problem. I´ve a model that i need to serialize. I´m using EA8 and VS2010/C#. In an Addin, i call the method SerializeObject:
private String UTF8ByteArrayToString(Byte[] characters)
    UTF8Encoding encoding = new UTF8Encoding();
    String constructedString = encoding.GetString(characters);
    return (constructedString);
private Byte[] StringToUTF8ByteArray(String pXmlString)
   Byte[] byteArray = encoding.GetBytes(pXmlString);
   return byteArray;
public String SerializeObject(Repository rep)
 try{
      String XmlizedString = null;
      MemoryStream memoryStream = new MemoryStream();
      XmlSerializer xs = new XmlSerializer(typeof(rep.GetType()));
      XmlTextWriter xmlTextWriter = new XmlTextWriter(memoryStream, Encoding.UTF8);
      xs.Serialize(xmlTextWriter, rep);
      memoryStream = (MemoryStream)xmlTextWriter.BaseStream;
      XmlizedString = UTF8ByteArrayToString(memoryStream.ToArray());
      return XmlizedString;
  catch (Exception e){
      System.Console.WriteLine(e);
      return null;
when executed this line:
XmlSerializer xs = new XmlSerializer(rep.GetType());
And exception ocurrs. The error is:
$exception      {"Unable to generate a temporary class (result=1).\r\nerror CS0122: 'System.__ComObject' is inaccessible due to its protection level\r\nerror CS0051: Inconsistent accessibility: parameter type 'System.__ComObject' is less accessible than method 'Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationWriter__ComObject.Write3___ComObject(string, string, System.__ComObject, bool, bool)'\r\nerror CS0122: 'System.__ComObject' is inaccessible due to its protection level\r\nerror CS0050: Inconsistent accessibility: return type 'System.__ComObject' is less accessible than method 'Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReader__ComObject.Read3___ComObject(bool, bool)'\r\n"}      System.Exception {System.InvalidOperationException}
How I can serialize rep?
Thanks. Regards
Re: Serialize Repository using C#
« Reply #1 on: October 26, 2010, 09:49:55 am »
EA automation objects don't support serialization.
What you probably want is to export to xmi.  (Which is available from the project interface from memory.)
