Author Topic: HowTo Add TaggedValueType by AddIn  (Read 4116 times)
RainerQ
« on: October 25, 2010, 09:02:35 pm »
what would be the appropriate way to add a TaggedValueType through a AddIn?
Thanks for hints and links.
Regards
Rainer
RainerQ
Re: HowTo Add TaggedValueType by AddIn
« Reply #1 on: October 26, 2010, 01:53:05 am »
ok, I found the answer  :)
private void AddPropertyTypeIfNotExisting(Repository repository, string property, string description, string notes)
            if(this.PropertyExists(property, repository)) return;
            string sql = string.Empty;
            sql = "INSERT INTO t_propertytypes (Property, Description, Notes) VALUES (";
            sql = sql + "'" + property + "', ";
            sql = sql + "'" + description + "', ";
            sql = sql + "'" + notes + "')";
            repository.Execute(sql);
Regards
Rainer
« Reply #2 on: October 26, 2010, 09:47:25 am »
The appropriate way would be more like
EA.PropertyType tagType = rep.PropertyTypes.AddNew(property, "");
tagType.Description = description;
tagType.Detail = notes;
tagType.Update()
Your code will break if any of those strings contain '.
« Last Edit: October 26, 2010, 09:48:56 am by simonm »
RainerQ
« Reply #3 on: October 26, 2010, 05:24:00 pm »
Hello Simon,
thank you very much for your advise!
I will refactor my code right away, since the appropriate way looks much nicer.
Regards
Rainer
