Author Topic: Dockable Window  (Read 6377 times)
stefanw
Dockable Window
« on: October 07, 2010, 11:45:19 pm »
hi,
I want to make my Plugin Window dockable to EA Main Window.
How does it works?
Best Regards,
Stefanw
Re: Dockable Window
« Reply #1 on: October 08, 2010, 12:14:18 am »
Stefan,
Look at Repository.AddWindow (string WindowName, string ControlID).
I haven't tried it myself, so I can't give you any examples.
stefanw
Re: Dockable Window
« Reply #2 on: October 11, 2010, 09:37:28 pm »
Stefan,
I haven't any ControlID for my Form. This is only possible if
I build an ActiveX COM-Class. I hate COM  :o
Is there any other possibility to dock a window?
Re: Dockable Window
« Reply #3 on: October 11, 2010, 09:45:20 pm »
TFM says:
Adds an ActiveX custom control as a window to the Add-Ins docked window. Enterprise Architect creates a control and, if successful, returns its Unknown pointer, which can be used by the caller to manipulate the control.
The window can be shown by selecting it from the list in the Workspace Layouts toolbar - click on the third icon from the right and look at the end of the list.
Parameters:
WindowName: String - used as the window title.
ControlID: String - the ProgID of the control; for example, Project1,UserControl1.
So I guess that's the only way to dock a window.
stefanw
Re: Dockable Window
« Reply #4 on: October 12, 2010, 12:48:53 am »
TFM says:
Parameters:
ok.
how can I get the ProgID, please?
« Last Edit: October 12, 2010, 12:50:03 am by stefanw »
Re: Dockable Window
« Reply #5 on: October 12, 2010, 04:01:38 am »
I'm not sure, but I'm guessing its going to be <your_project_name>.<your_control_name>
Frank Horn
Re: Dockable Window
« Reply #6 on: October 12, 2010, 05:55:23 am »
The ProgID is a registry key under HKEY_CLASSES_ROOT with a subkey CLSID. When you build your AddIn and/or your control with something like Microsoft Visual Studio there will usually be some assistant to create a new project, and the ProgID will be like Geert says.
When your not sure, search the registry for the full path of your dll. You'll find it under "HKEY_CLASSES_ROOT/CLSID/{some guid}/InProcServer32". Then search for that guid, which you will find under HKEY_CLASSES_ROOT/your-prog-id/CLSID.
stefanw
Re: Dockable Window
« Reply #7 on: October 19, 2010, 02:54:33 am »
I get an Email from Sparks Support with this link
http://www.sparxsystems.com/enterprise_architect_user_guide/8.0/automation_and_scripts/repository3.html
Now, it works  ;)
thank you!
but I have a further problem. I think the method CloseAddins is used to close the addin. I get no compiler error, but it doesn't works  :(
any idea?
stefanw
Re: Dockable Window
« Reply #8 on: October 27, 2010, 12:16:48 am »
in which EA built the function were implemented, please?
Built 844 is EA 7.5 - not implemented
Built 863 is EA 8.0 - implemented
but I need the exactly Built
Re: Dockable Window
« Reply #9 on: October 27, 2010, 03:57:56 am »
look in the release notes.
There should be a line about the AddWindow.
stefanw
Re: Dockable Window
« Reply #10 on: October 28, 2010, 08:59:55 pm »
I found the Release Note in the Readme.txt in EA Directory
AddWindow were Implemented in Built 855
Thank you for your help  ;)
