Author Topic: Version 3.10 - Build 495 released  (Read 31460 times)
sparks
« on: June 13, 2002, 06:47:59 am »
Changes and Fixes for Build 495
- Reworked and updated the docked properties window extensively
- Added support for Tagged Values to the Docked Property Browser
- Added support for Delegates to C# parser/generator
- Added ability to set the extension for all filenames generated in HTML report (eg. .htm, .asp, .html)
- Added support in 'Link Note to Element Feature' for Tagged Values
- Allow empty notes field in Scenario tab of object properties
- Update HTML reporting to show icon for contained packages in lower left Contents pane
- Changed 'Set Run State' shortcut key tot "Shift+Ctrl+R"
- Added check box to search dialog - allows search to include scenarios, constraints, requirements and tagged values for object in search
- Fixed bug in Delphi parser that caused problems with overloaded functions under some circumstances.
- Added check in Operations dialog for unsaved changes when selecting another Operation from list.
