Author Topic: formatting notes from elements  (Read 22049 times)
DanielL
« on: November 02, 2010, 10:18:08 pm »
I want to add an note to an element via the SDK API. This works fine. But I'm not able to add a formatted string.
I have seen, that the EA uses HTML style formats for notes of elements.
I tried to add a note with a string like this:
"<div><p>my note</p></div>".
But if you look later into the EA you see exactly the string without any formatting.
Is it possible to add new notes with HTML-style string formats to the elements?
best regards
Daniel
Re:  formatting notes from elements
« Reply #1 on: November 03, 2010, 08:34:06 am »
Look for GetFieldFromFormat (string Format, string Text) in the user guide.
Converts a field from your preferred format to Enterprise Architect's internal format. Returns the field in Enterprise Architect's internal format.
Parameters:
Format: String - The format to convert the field from. Valid formats are:
HTML - Full HTML
RTF - Rich Text Format
TXT - Plain text
Text: String - The field to be converted.
DanielL
« Reply #2 on: November 03, 2010, 06:26:50 pm »
Thank you!
It works fine.
Daniel
