Author Topic: Element appearance + selectable  (Read 5436 times)
RainerQ
« on: November 05, 2010, 11:25:32 pm »
I would like to modify the Font (Appearance->SetFont) of a boundary element and I also would like to set this boundary to "not selectable".
How can this be done?
Note : I already have the element instance in my code available.
Regards
Rainer
« Last Edit: November 05, 2010, 11:26:36 pm by RQ »
Re: Element appearance + selectable
« Reply #1 on: November 06, 2010, 02:27:09 pm »
HI Rainer,
to get non-selectability, you need to add/merge
NSL=1; to the object.Style attribute.
HTH.
RainerQ
« Reply #2 on: November 06, 2010, 06:45:44 pm »
Hi Paolo,
thanks, NSL=1; works nicely. Now I only need to know how to set the Font.
Regards
Rainer
« Reply #3 on: November 08, 2010, 05:31:51 pm »
Rainer,
I don't know how to set the font, but here's how I would try to figure out.
- Create a new empty model
- Create and element with standard font setting and an element with adjusted font.
- Open the database and figure out what the difference is between the two elements. In this case I would specifically look at t_object and t_diagramobject. The font will probably be hidden somewhere in the style columns.
If this doesn't work, a database trace can also help as it shows wich SQL statements are being executed by EA when you change the font.
RainerQ
« Reply #4 on: November 08, 2010, 08:12:22 pm »
Hi Geert,
thanks for your suggestions. I also thought about this way, but was still hoping for a easier solution ;-)
I guess I will walk on this path when I am done with my other tasks and have not received a easier solution ...
Regards
Rainer
« Reply #5 on: November 09, 2010, 08:52:46 am »
Correct. Specifically, t_diagramobjects.ObjectStyle and t_object.Fontcolor
RainerQ
« Reply #6 on: November 09, 2010, 08:29:11 pm »
Geert, KP,
I walked this path and it now works fine.
Thanks for your help!
Regards
Rainer
