Author Topic: Code Generation Template C-style Comments  (Read 3987 times)
lehpat
« on: November 25, 2010, 07:16:19 pm »
in my sepcifications I have to generate comments for methods like that:
/* Class::Method(Params)                                                            */
/* Description :        */
/* Parameter   :        */
I got nearly everything working, except that the dynamically created content destroys the alignment of the border. How can I manage to align the */ at the line end?
Re: Code Generation Template C-style Comments
« Reply #1 on: November 26, 2010, 08:14:26 am »
You may be able to use WRAP_LINES.
WRAP_LINES(<text>, <wrap_length>, <start_string>[, <end_string])
Wraps <text> as designated to be <wrap_length>, adding <start_string> to the beginning of every line and <end_string> to the end of the line if it is specified.
lehpat
« Reply #2 on: November 26, 2010, 08:08:34 pm »
This does not work, because the line is not filled up with spaces, so the Comment looks like that:
/* Description :  foobar  */
/* Parameter   :  foo  */
« Reply #3 on: November 29, 2010, 09:01:47 am »
Then I don't think you can do it without writing an add-in and getting that to format your notes for you.
