Author Topic: Changing Association to Realization  (Read 5992 times)
Saul
« on: December 14, 2010, 04:36:27 pm »
I have an association between a use-case elemnt and a requirement element. I can change the connector type between them from 'Association' to 'Realization' using the COM API, however the requirement doesn't show up in the use-case as an 'External Requirement' as I would hope.
Looking at the API documentation there doesn't seem to be any way to add an existing requirement element as an external requirement to a use-case.
Am I missing something?
Aaron B
Re: Changing Association to Realization
« Reply #1 on: December 14, 2010, 04:59:18 pm »
Which element is the Source (Client) and which is the Target (Supplier) of the connector?  I think the Use Case should be at the Client end and the Requirement should be at the Supplier end.  Also might be worth confirming that Connector.Direction is set to "Source -> Destination".
Saul
« Reply #2 on: December 14, 2010, 05:24:31 pm »
Yes, the source is the use-case and the target is the requirement.
I didn't have direction specified, but I've fixed that now...no change.
The "realization" I create in the UI looks identical to the one created via the API...except for the fact that nothing shows up in the Use-Case External Requirements list.
Saul
« Reply #3 on: December 14, 2010, 10:03:23 pm »
OK, I've found the solution.
You need to set the connector type to 'Realisation' *not* 'Realization' as described in the API spec (under Connector).
I think this might be a bug - at least a documentation bug.
Saul
« Reply #4 on: December 16, 2010, 02:03:44 pm »
Saul
Hi Saul,
Which version & build of EA are you running?
The Realization/Realisation dichotomy should have been fixed as of 850 or so... See: Dear Geoffrey...
