Author Topic: scripting  (Read 4287 times)
george75
scripting
« on: December 15, 2010, 05:25:33 am »
I want to write vbscript for the EA-Project Browser.
All works perfect, but when I want to declare a static variable or a normal variable(e.g. dim x as integer) or just an function (e.g. fuction xxx() as boolean .....) an error occurrs.
What I'm doing wrong
thanks
mrf
Re: scripting
« Reply #1 on: December 15, 2010, 08:55:26 am »
Hi George,
It's hard to get a picture of what's going wrong from the description you have provided.
1. What error message are you getting?
2. Are you using the default Project Browser script template?
3. Would it be possible to send a copy of the script to sparx support so that we can try and debug it ourselves.
Best Regards,
Michael
Re: scripting
« Reply #2 on: December 16, 2010, 05:10:40 pm »
George,
I'm in no way a specialist, but isn't vbscript weakly typed?
If I'm correct that would mean that you have to declare variables and functions without a type.
So iso
Dim myVariable as integer you type
Dim myVariable
Re: scripting
« Reply #3 on: December 17, 2010, 11:17:41 am »
EA allows Dim ... as when using EA types, for example
Dim MyElement as EA.ElementThis allows you to use intellisense in the editor. However trying the same thing with a non-EA type will cause an error, for the reason that Geert gave.
« Last Edit: December 17, 2010, 12:40:23 pm by KP »
