Author Topic: requirements trace  (Read 4850 times)
dean.warren
requirements trace
« on: December 14, 2010, 12:17:13 am »
I require to extract details related to requirements trace. Where a requirements trace is when, for example, a requirement is dropped on to a diagram and a trace is used to associate the requirement to a component.
I have noted the trace is described in the 'Links' tab of the Component Properties.
How do I find all traces of requirement type in the model using the automation interface?
So far I am looking at the Connection class?
philchudley
Re: requirements trace
« Reply #1 on: December 14, 2010, 03:10:49 am »
Hi
Assuming that you wish to start at an element and then identify the requirements realised by an element, then the following would work
public ArrayList getAllRequirements(EA.IDualElement useCase)
            // Get the connectors for this use case
            EA.IDualCollection connectors = useCase.Connectors;
            ArrayList requirements = new ArrayList();
            // iterate the connectors looking for realizations and add the
            // requirement which it is the supplier to the ArrayList
            foreach (EA.IDualConnector connector in connectors)
                if (connector.Type == "Realisation")
                    EA.IDualElement common = currentModel.GetElementByID(connector.SupplierID);
                    if (common.Type == "Requirement")
                        requirements.Add(common);
            return requirements;
Where currentModel is an instance of an EA.Repository class
The above code template could be adapted for, beginning at a Requirements then returning all elements realising that requirement, something, like this:
public ArrayList getAllRealisingElements(EA.IDualElement requirement)
            // Get the connectors for this requirement
            EA.IDualCollection connectors = requirement.Connectors;
            ArrayList realisers = new ArrayList();
            // element which it is the client to the ArrayList
                    EA.IDualElement common = currentModel.GetElementByID(connector.ClientID);
Cheers
Phil
Phil
Models are great!
dean.warren
« Reply #2 on: December 22, 2010, 10:26:30 pm »
Thanks Phil - by the time I read this I already gone dopwn a different avenue.
However...
I have iterated over Elements looking for Connectors whose properties were Trace and Dependancy (this give me the trace asscoiatations). I then use the Client and Supplie ID's to locate either end of the trace association. Next I filter the association ends on Components And Requirements.
What is the IDualElement and why would I use it?
« Last Edit: December 22, 2010, 10:27:29 pm by dean.warren »
