Author Topic: Add-In: difficult start  (Read 5557 times)
romu
« on: December 23, 2010, 02:33:53 am »
Dear all,
Pretty new here.
I've just started an add-in project, written in C#, targetting .Net 2.0 and running on my Windows 7 64 PC.
I started from the CS_AddinFramework example, just changed some names, nothing more. It compiles well.
I tried to register it through VS, but also manually on both 32 & 64 .Net frameworks.
I also created the registry key in the LOCAL_MACHINE and CURRENT_USER hives.
And the problem is: I get absolutely nothing when I run EA. I thought this example should at least be visible in the add-ins window, but that's not the case. My breakpoint in EA_Connect is never reached.
One more information: my current user account has not the administration privileges.
Thanks for the help.
romu
Re: Add-In: difficult start
« Reply #1 on: December 23, 2010, 03:51:17 am »
Ok, I got it.
The problem came from the way I don't work with an administrative account. So, I had to :
- switch to the admin account,
- get my account SID
- add the elements under my account key
And it works.
But that's a bit tricky. So my question is: is there a way to register an add in for all users? (I tried to add the key in LOCAL_MACHINE and USERS\.DEFAULT and in both cases, it doesn't work).
« Reply #2 on: December 23, 2010, 08:12:44 am »
Not in the current build.  We do have a change coming to allow add-in keys in LOCAL_MACHINE.
PS. I've looked at USERS\.DEFAULT before and I believe you have misinterpreted what it is for.
romu
« Reply #3 on: December 23, 2010, 07:30:08 pm »
Thanks for your answer.
I didn't search, but after some brainstorming, I guess .DEFAULT it used when a new user account is created. That's not the case here.
Can you provide an estimation date for the release with the LOCAL_MACHINE change?
Thanks.
Aaron B
« Reply #4 on: December 24, 2010, 09:57:32 am »
Hi romu,
The change Simon M referred to is currently planned to be in the next major version of EA, but we can't provide any timeline for it's release as yet.
« Last Edit: December 29, 2010, 08:58:27 am by AaronB »
romu
« Reply #5 on: December 24, 2010, 07:36:52 pm »
Ok, thanks and Merry Christmas.
