Author Topic: Connectors-limit endpoints to defined stereotypes  (Read 3534 times)
harvinder
« on: December 29, 2010, 09:02:22 am »
I have created [using shape script and stereotype in profile] a custom connector.
I am wondering if I can limit the end point to certain stereotypes only, i.e it should not be possible to draw connection between two unsupported stereotypes.
cheers
harvinder
Re: Connectors-limit endpoints to defined stereoty
« Reply #1 on: December 29, 2010, 10:08:27 am »
Currently not possible. The closest you can get is to write a model validation add-in that will validate your model after you have created it.
« Reply #2 on: December 29, 2010, 12:02:16 pm »
Another "trick" I use is to set up the QuickLinker for the profile to draw a VERY obviously badly drawn connector between two invalid stereotypes.  Mine draws a thick red line with red ovals at either end with the stereotype «INVALID».
Sure stands out and people soon learn not to join the two invalid stereotypes.
harvinder
« Reply #3 on: December 29, 2010, 04:41:31 pm »
I have got another, but not a perfect solution...
the only problem is, that, I can create a valid connection and later drag one end to the not supported stereotype element...
        bool EA_OnPreNewConnector(Repository repository, EventProperties info)
            bool foundMyConnector = false;
            bool foundValidEnds = true;
            foreach (EA.EventProperty eventproperty in info)
                if ("Stereotype" == eventproperty.Name && "MyConnector" == eventproperty.Value.ToString())
                    foundMyConnector = true;
                if ("SupplierID" == eventproperty.Name || "ClientID" == eventproperty.Name)
                    int supplierID = System.Convert.ToInt32(eventproperty.Value);
                    Element supplier = repository.GetElementByID(supplierID);
                    if (!supplier.Stereotype.Contains("MyStereotypEnd"))
                        foundValidEnds= false;
            if (foundMyConnector)
                return foundValidEnds;
            else
                return true;
