Author Topic: Instancing UML Pattern  (Read 3549 times)
Diego Martinez
« on: January 05, 2011, 07:44:15 am »
Hi to everybody,
I am using UML Patterns functionality to automate the creation of certain component diagrams. The "Save as UML Pattern..." feature asks me, for each object / node in the diagram, the instance action (Create, Merge, Instance). It also lets me specify a default value (Default).
What I'm looking for is that when I later instance the pattern, certain objects/nodes do not ask me for the instance action (Create or Merge or Instance). I would like that a merge is automatically made using the default value I indicated at the time of the creation of the pattern.
I cannot make it work.
According to the EA documentation, the merge or instance action, in combination with the default value, should be used to accomplish what I'm looking for, but I don't have luck: when instancing the pattern, the EA always asked information for all the objects/nodes.
Any suggestion?
Thanks in advance for any help,
Diego
Re: Instancing UML Pattern
« Reply #1 on: January 05, 2011, 07:20:26 pm »
Diego,
Looks like the api is not doing what it is supposed to do according to the documentation -> bug. You can report it using the link on the bottom of the page.
As a workaround you could try to use Repository.SuppressEADialogs
(no guarantees).
Diego Martinez
« Reply #2 on: January 06, 2011, 12:28:07 am »
Sorry Geert, I forgot to mention that I'm NOT USING the API!
I'm working direclty with the EA visual interface.
I'm using 8.0.856 version.
Thanks again,
Diego
« Reply #3 on: January 06, 2011, 12:34:05 am »
Diego, in that case you better start a topic in the general board forum.
Here we are supposed to discuss API and Addin stuff.
Diego Martinez
« Reply #4 on: January 06, 2011, 12:45:18 am »
OK.
I misunderstood this discussion's description.
New topic: http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1294234895.
Diego
