Author Topic: How to make an element Composite via API  (Read 9146 times)
Gian Luca
« on: February 26, 2010, 09:19:43 pm »
Hello to everyone,
I would like to create programmatically the Make Composite GUI operation.
I'd tried several ways with no success.
Latest tentative was (c#):
application = (Element)myPackage.Elements.AddNew("My new Element", "Component");
application.Alias = myalias;
application.Stereotype = "Applicativo";
application.Update();
// create the composite diagram inside element
composite = (Diagram)application.Diagrams.AddNew(application.Name, "CompositeStructure");
composite.Update();
application.Subtype = 8;  // Composite
At the end I see the CompositeDiagram as child of the element application and application marked as composite, but without the infinite symbol ! And if I double click on the element application (previouly inserted in a diagram) I see the properties windows instead of the proper Composite Diagram.
Please help me !
Thanks in advance !
Gian Luca (Torino, Italy)
« Last Edit: February 26, 2010, 09:21:18 pm by glfp »
Re: How to make an element Composite via API
« Reply #1 on: February 26, 2010, 09:35:33 pm »
Gian
Have you searched the forum for "composite". (use the top left button, not the top right input field)
I'm pretty sure your question has already been answerred before. (but I don't recall the details)
Gian Luca
« Reply #2 on: February 26, 2010, 09:40:02 pm »
Gian
Mmm .... you are right .... I used to top right search ... sorry, I found several topic now .... i'll try this way !
Thanks !
« Reply #3 on: February 26, 2010, 09:42:01 pm »
No worries, it IS the most logical thing to do (use the top right box)
Unfortunately this forum isn't really logical ;)
Gian Luca
« Reply #4 on: February 26, 2010, 11:30:58 pm »
unfortunately it seems there is no solution for this issue.
The only way (that I alrealy identified) is to change/create the correct record in  t_xref table.  :(
It's described here
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1217982429/15
you also replied .
A EA Administrator  said here (on 2008)
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1217982429/10#10
that he was envolved in a isComposition attribute to define it as composite but without results.
I think is not a good idea to write directly on DB ...
What do you think about this ?
Thank you !
« Reply #5 on: February 27, 2010, 12:19:21 am »
Gian,
I absolutely agree that it's a bad idea to write directly in the database.
I suggest that you file a bug report/support request.
Usually the Sparxians are happy to help you out with a specific question.
Use the link on the button of the page to report the bug.
Gian Luca
« Reply #6 on: February 27, 2010, 12:29:27 am »
Gian,
I will ! Thanks.
« Reply #7 on: January 17, 2011, 11:36:36 pm »
Any results here?
« Reply #8 on: January 17, 2011, 11:50:33 pm »
Should be included in V 9 according to this post: http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1294607049/1#1
« Reply #9 on: January 19, 2011, 07:46:50 am »
Thanks. Would be nice to trash my INSERT INTO t_xref which is really a PITA.
