Author Topic: OnPostNewElement strange behavior  (Read 6305 times)
« on: January 22, 2011, 05:03:17 am »
I wonder if anyone else has encountered this: When I create an element from my MDG toolbox (a stereotyped Use Case) the OnPostNewElement event is fired AFTER the properties dialog has been closed. In contrast when I create a simple Use Case (from UML) the event is fired prior to opening the properties dialogue.
I'll report a bug any way.
Re: OnPostNewElement strange behavior
« Reply #1 on: January 24, 2011, 11:29:55 am »
Hi q,
I've also noticed strangeness when comparing behaviour on toolbox elements versus non-toolbox - in my case using the standard UI.
For example, if you draw an Association from the toolbox, subsequent F3s (redraw the last relationship type) will draw Directed Associations; whereas if you use the QuickLinker to draw a (specifically) Directed Association, subsequent F3s will draw Undirected Associations.
« Reply #2 on: January 26, 2011, 02:23:41 am »
Bug confirmed by Sparx.
