Author Topic: exception when trying to add new connector  (Read 6769 times)
ami
« on: January 31, 2011, 05:14:05 pm »
I'm trying to add a new connector to the element and when performing Update(); I'm getting an exception
The server threw an excepption. (exception from HRESULT: 0x80010105(RPC_E_SERVERFAULT)).
any ideas why? what is the meaning of this message?
Re: exception when trying to add new connector
« Reply #1 on: January 31, 2011, 05:37:41 pm »
First thought is that you need to set the connector's ClientID and SupplierID before calling Update. If that isn't the problem, could you show us your code please?
ami
« Reply #2 on: January 31, 2011, 06:13:40 pm »
I called Update() after setting client and supplier and yet same exception is showing.
the code is:
Element newElem = (Element)m_ElemUseCase.Elements.AddNew("NewElement", "Activity");
newElem.Update();
Connector con2 = (Connector)newElem.Connectors.AddNew("Con", "Transition");//create connector from new element to one below
con2.ClientID = m_ListActivities[rowIndex].ElementID;
con2.SupplierID = m_ListActivities[rowIndex + 1].ElementID;
con2.Update();
if you dont understand something - ask me...
thanks-
Ami.
« Reply #3 on: January 31, 2011, 07:42:29 pm »
Ami,
If normally you shouldn't set the ClientID, only the supplierID (since the connector was added on newElem.
You better check if indeed the ClientID == newElem.ElementID
PS. What version are you on? There could have been a fix for this issue...
ami
« Reply #4 on: January 31, 2011, 07:47:31 pm »
Hi geert,
I will check if I have to.
my version is 8.0.858
ami
« Reply #5 on: January 31, 2011, 07:58:59 pm »
I just want to say that this is the way I was working till today (I'm talking about the client - supplier) and my code worked just fine, I dont know what went wrong...
« Reply #6 on: January 31, 2011, 08:17:46 pm »
Sometimes Repository.GetLastError() provides some useful information.
ami
« Reply #7 on: January 31, 2011, 08:24:06 pm »
I will try it and tell you the results
Ami.
ami
« Reply #8 on: January 31, 2011, 08:28:02 pm »
GetLastError() just return an empty string...
so its not EA exception??....
Ami.
