Author Topic: Adding a Element to a diagram  (Read 4358 times)
Rossco
« on: February 02, 2011, 12:07:44 pm »
Hi I am trying to add an element to a diagram using C#
I have the diagram and the element and a using the sample VB.net based code
EA.Diagram MyDiagram = MyRepository.GetCurrentDiagram();
                    EA.DiagramObject O;
                   O = MyDiagram.DiagramObjects.AddNew("l=200;r=400;t=200;b=600;", "");
I get the following error
Cannot implicitly convert type 'object' to 'EA.DiagramObject'. An explicit conversion exists (are you missing a cast?)
Any Ideas on how this should work
Regards
Ross
Aaron B
Re: Adding a Element to a diagram
« Reply #1 on: February 02, 2011, 04:03:52 pm »
Like the message from Visual Studio suggests - you need to explicitly cast the object returned from AddNew to an EA.DiagramObject type.  E.g.
EA.Diagram MyDiagram = repository.GetCurrentDiagram();
EA.DiagramObject O;
O = (EA.DiagramObject)MyDiagram.DiagramObjects.AddNew("l=200;r=400;t=200;b=600;", "");
Same principle will also apply when using other collections such as Elements, Packages, etc.
« Reply #2 on: February 02, 2011, 04:05:06 pm »
Hi Ross,
You need to explicitly cast the (generic) Object returned from AddNew... Thus:
Bit of a PITA, but once you get used to it...
« Last Edit: February 02, 2011, 04:05:48 pm by PaoloFCantoni »
Rossco
« Reply #3 on: February 03, 2011, 05:41:48 am »
Thanks guys ;D
Oh - how easy in hindsight!
