Author Topic: Filtered Implementation Report  (Read 3633 times)
Brian Hayes
« on: February 04, 2011, 04:43:24 am »
Is there way to create an Implementation Report that is filtered so that elements of specific Status values, Phase values, or tag values are shown?  I would prefer to use EA directly rather than using automation.
Thanks.
alesliehughes
Re: Filtered Implementation Report
« Reply #1 on: February 04, 2011, 08:54:24 am »
Yes, On the RTF Generation dialog add an "Element Filter" with the restriction you require.
NOTE: The current build will exclude child element if the parent is filtered out.  This has been correced for the next major build.
Alistair
Brian Hayes
« Reply #2 on: February 04, 2011, 09:46:40 am »
Thanks.  I still need some help.
I can see that I can specify an Element Filter, say Status Contains Approved and check Include and Required.
I do not understand how a specify that I want an implemented/realized by relationship/association.  Is this possible?
alesliehughes
« Reply #3 on: February 04, 2011, 10:32:47 am »
Would the exclude Connector types on the "Options" page of the RTF Generate dialog help?
Alistair
