Author Topic: How to check if a Element exist on the diagram  (Read 5261 times)
Mithal
« on: February 08, 2011, 08:01:57 pm »
Hi.
How can i check if an Element with Name "CustomerName" already exist on the diagram
I tried newDiagram.DiagramObjects.GetByName("CustomerName");
and it throws an exception.
Thanks in advance.
SomersetGraham
Re: How to check if a Element exist on the diagram
« Reply #1 on: February 08, 2011, 08:14:52 pm »
Mithal
This is the expected behaviour if the collection does not contain "CustomerName"
see http://www.sparxsystems.com/enterprise_architect_user_guide/8.0/automation_and_scripts/collection.html
Graham
Using V12
« Reply #2 on: February 08, 2011, 08:33:57 pm »
Mithal,
I don't ever use Collection.GetByName as it doesn't work on all collections, and the results are random when there are multiple elements with the same name.
You better do a foreach and check the elements yourself. (or use an sqlQuery if performance is an issue)
Mithal
« Reply #3 on: February 08, 2011, 09:10:55 pm »
Hi, i am using this code
EA.Element textElement = (EA.Element)parentPackage.Elements.GetByName("CustomerName");
Seems to work.
Please advise if ishould not be doing this.  I appreciate you guys response to my query.
« Reply #4 on: February 08, 2011, 09:19:17 pm »
Mithal,
What happens if you have two (or more) elements with the name "CustomerName" in your package?
Which one will be returned? -> result is unpredictable.
Mithal
« Reply #5 on: February 08, 2011, 09:22:46 pm »
Thats good point.  What i will do is give the text Element a Name like zzzSYSPROCompanyName, something not very auvious.
but i will use a loop so i update the first occurence.
Thanks for your Help.
