Author Topic: Repository.getElementSet  (Read 7409 times)
christian81
« on: February 12, 2011, 02:54:11 am »
hi there,
how can i use this funcion if i want to get all available models in a repository?
i guess to use a list of id´s don´t help me because i don´t know how much models are available.
Thx
stao
Re: Repository.getElementSet
« Reply #1 on: February 12, 2011, 11:31:03 pm »
foreach(EA.Package actModel in Repository.Models)
should be do what you want.
christian81
« Reply #2 on: February 17, 2011, 08:58:35 pm »
thx for your answer.
if i want to use this code in VBA i should use
For each Pack In Repository.Models
right?
But actually i really want to now what this funcion Repository.getElementSet() is doing.
I found the description in the help directory:
" ....Returns a set of elements as a collection based on an input of element ID numbers in comma separated form. eg. GetElementSet("34,56,21,5").... "
Should i put this function in a loop in order to get a collection of these ID numbers? How it works?
Thx
« Reply #3 on: February 17, 2011, 09:14:10 pm »
GetElementSet can be used when you already know the id's of the elements you need, but you don't have the actual EA.Element objects yet.
(you can also pass an sql string to get those id's)
christian81
« Reply #4 on: February 18, 2011, 12:30:38 am »
If i know the id´s of elements. how it´s work then...
Dim coll as New Collection
Dim i as integer
for i = 0 to 2
     coll.add item:=Repository.getElementSet("71,81,169",1)
i guess this kind of code is not the right thing...
thx
« Reply #5 on: February 18, 2011, 12:45:56 am »
Repository.GetElementSet already returns a collection.
I don't see why you would request that multiple times.
May I ask what exactly you are trying to achieve?
christian81
« Reply #6 on: February 18, 2011, 01:08:25 am »
oh no... you are right.. the return value is a collection...
I want to find out the easiest way to get all available elements in a repository. Is this the right way to use  this function?
Mycollection = Repository.getElementSet("71,81,169",1)
« Reply #7 on: February 18, 2011, 01:18:40 am »
Looks like a correct usage of getElementSet
christian81
« Reply #8 on: February 18, 2011, 01:48:25 am »
now i got this....
Dim testCon as New collection
    Set MyCollection = Repository.GetElementSet("71,81,169", 1)
    For Each Item In MyCollection
         testCon.Add Item:=Item
    Next
