Author Topic: Change of metatype  (Read 4639 times)
Jiří Hegr
Change of metatype
« on: March 15, 2011, 12:19:54 am »
Hello
We have a requirement model in SysML. There were more users then one who worked on it and now I need to repair a few requirements metatypes (from requirement to functionalRequirement). I created an add-in in C# but it seems, that metatype attribute of an element is read-only, so after the change update method does not work. Is there any way how to change an element metatype?
Thank you for your help,
J. Hegr
Re: Change of metatype
« Reply #1 on: March 15, 2011, 01:08:07 am »
Those types of things are usually much easier if you just update the database.
Jiří Hegr
« Reply #2 on: March 15, 2011, 06:12:41 pm »
Thanks for advice. I have found where are requirement elements I need to fix. But I really did not discover what ID is related to metatype and what table does it contain. The table t_xref is promising but its id is not used in requiremet element.
Could you give me any hint?
J. Hegr
« Reply #3 on: March 15, 2011, 08:16:45 pm »
You should send a priority support request to Sparx.
