Author Topic: Enterprise Architect MDG Integration for Visual St  (Read 3918 times)
ovargas
« on: March 31, 2011, 11:36:50 am »
I´m using the AddIn Enterprise Architect MDG Integration for Visual Studio, version 4.0.0. with Enterprise Architect 7.5 and TFS 2010.
My entire Use Case Model is in EA and I need to create a Work Iten for each Use Case attaching the EA Model in a Prohject Solution in TFS, so far there´s no problem but there´s a problem with de TFS connection.
VS2010 ultimate is connected to the TFS server but, if I close Visual studio I can´t connect again with TFS, there´s any way to reconect again or change the connection parameters?
Another question: this AddIn only works with VS201o Ultimate?
Re: Enterprise Architect MDG Integration for Visua
« Reply #1 on: April 01, 2011, 10:22:13 pm »
I wish I had better news for you but...
You can find - though not easily - the description page for version 4.0 here. It seems that no version of VS2010 is supported.
If this is the case you appear to be in a bit of a bind. According to the latest release page version 4.5 supports VS2010, but requires EA build 864 or later.
hth,
ovargas
« Reply #2 on: April 02, 2011, 02:03:52 am »
Thanks a lot, lets see if we can migrate to EA 8
ovargas
« Reply #3 on: April 06, 2011, 04:58:14 am »
There´s anpther issue..
- I uninstall MDG Integration 4.0 and EA 7.5 for testing MDG 4.5 with EA 8.0, both in trial version
- The uninstall was successful but EA 7.5 continues available, it was removed by hand, ran the "CCleaner tool" and reinstall EA 8.0 trial and MDG 4.5
When I open VS2010 and attach an EA Model or import an .xmi model, it opens a window and the MDG  references to EA 7.5
Do you know why?, how could we switch this reference to EA 8.0?
