Author Topic: Java Automation Example  (Read 3852 times)
brettonwoods
« on: April 11, 2011, 10:31:43 am »
I have a list of about 450 requirements for a project that I would like to import using the java interface. I'm working in Eclipse and have copied the files as per instructions and have connected to the repository. Does anyone have a java snippet for inserting the requirements?
Thanks for any help!
Re: Java Automation Example
« Reply #1 on: April 11, 2011, 01:29:29 pm »
Have you seen the Java code samples in your install directory?  They may not provide exactly what you're after but they should be fairly close.
brettonwoods
« Reply #2 on: April 12, 2011, 09:07:13 am »
Over the weekend  I was reading the docs on line at home off the web and didn't have access to EA so I missed the samples.
I created a project in Eclipse at work today, loaded the samples and the worked great after changing the class loader.
The samples got the job done.
