Author Topic: Change diagram types via script  (Read 11866 times)
Polymorph
« on: August 17, 2016, 08:30:31 am »
I have created an MDG that extends the SysML sequence diagram and need to change some of my sequence diagrams to this new type. Unfortunately, EA won't let me change a sequence diagram to any other type of diagram (that option is greyed out in the menu).
I am guessing that it must be possible somehow but that it might need to be done using a script...
From digging around in the SQL database it seems that the following field in the t_diagram.StyleEx table makes reference to the type of diagram. For example, on my standard SysML Sequence diagram this field reads:
ExcludeRTF=0;DocAll=0;HideQuals=0;AttPkg=1;ShowTests=0;ShowMaint=0;SuppressFOC=0;INT_ARGS=;INT_RET=;INT_ATT=;SeqTopMargin=30;MatrixActive=0;SwimlanesActive=1;KanbanActive=0;MatrixLineWidth=1;MatrixLineClr=0;MatrixLocked=0;TConnectorNotation=UML 2.1;TExplicitNavigability=0;AdvancedElementProps=1;AdvancedFeatureProps=1;AdvancedConnectorProps=1;ProfileData=;MDGDgm=SysML1.3::Sequence;STBLDgm=;ShowNotes=0;VisibleAttributeDetail=0;ShowOpRetType=0;SuppressBrackets=0;SuppConnectorLabels=0;PrintPageHeadFoot=0;ShowAsList=0;Whiteboard=1;SuppressedCompartments=;SaveTag=4B2FDBD8;
So, I was thinking that it might be possible to write a script to change this value
I am very new to EA scripting and have very little VB experience, but have managed to get a script to to a find-and-replace within this field using the following code:
sub OnDiagramScript()
' Get a reference to the current diagram
dim currentDiagram as EA.Diagram
set currentDiagram = Repository.GetCurrentDiagram()
'declare variable to store style string
dim DiagramStyleString
'store style string
DiagramStyleString = currentDiagram.StyleEx
'do a find a replace
DiagramStyleString=replace(DiagramStyleString,"MDGDgm=SysML1.3::Sequence;","MDGDgm=Protean Architecture Framework::System Interaction View;")
    currentDiagram.StyleEx=DiagramStyleString
end sub
But that didn't work - not that I'm surprised!
Re: Change diagram types via script
« Reply #1 on: August 17, 2016, 09:01:22 am »
currentDiagram.Update() to save the changes
Polymorph
« Reply #2 on: August 17, 2016, 05:10:45 pm »
So that's the only thing I need to do to change a diagram type? Really??? I'm not complaining if that's right but I'm frankly amazed (given my lack of experience with VB scripts) that I hit on the right idea straight away! Beginner's luck perhaps?
« Reply #3 on: August 18, 2016, 08:24:21 am »
Except that you can't change it via scripting in the current version.
There is a change coming that will allow writing to Diagram.Metatype, it's just not available yet.
Polymorph
« Reply #4 on: August 18, 2016, 10:08:48 pm »
And there's no other way to change it?!?  :-\
I have tried creating a new Sequence diagram (using our MDG technology) and then copy-pasting elements between the current diagram and the new one but that only copies the lifelines and any diagram fragments - the message lines are not duplicated.
I don't really care how I do it - I just need a way to take the contents of a standard Sequence diagram and then produce a version that conforms to our company standard
« Reply #5 on: August 19, 2016, 08:08:44 am »
You can change it with a SQL through Repository.Execute. This is an undocumented and unsupported feature, but it works. Of course you need to be extra careful since you can simply clobber your whole repository.
Polymorph
« Reply #6 on: August 19, 2016, 05:34:04 pm »
Gulp!
So I guess I have to ask myself the question: do I feel lucky?... Well do I? PUNK!
(No I don't feel lucky - not given my lack of experience with VB script writing)
And no one knows a way of copying the contents of a Sequence Diagram into clipboard and then pasting those elements including messages between lifelines-lines onto a new diagram?
« Reply #7 on: August 19, 2016, 07:54:50 pm »
In the browser right click the diagram/Copy/Copy Diagram. Right click package: Copy/Paste Diagram (and choose a new name)
Polymorph
« Reply #8 on: August 19, 2016, 07:55:55 pm »
I have found an alternate solution too!
The process I was using to copy the elements on a sequence diagram is:
  • Selecting all the elements on the diagram (CTRL + A).
  • Using CTRL + C to copy to clipboard
  • Creating a new sequence diagram (with my custom MDG extensions including a bespoke diagram frame tag)
  • Ctrl +V to paste the elements on the diagram
The result of this process was a complete mess - and none of the messages between lifelines were recreated in the diagram and all of the diagram fragments were all over the place  ::)
The way to do it is to follow steps 1-3, but when you have created a new diagram either
  • Right click on the diagram canvas and select Paste Elements as New
  • Use the keyboard shortcut (CTRL + SHIFT + V)
Now EA will replicate all the original features of the diagram in a new diagram perfectly.
Not the first time I've been caught out with differences between pasting as links and pasting as new elements :o
