Author Topic: Generate DOCX with cross-references  (Read 4908 times)
andresch
« on: August 17, 2016, 04:20:01 pm »
is it possible to integrate cross-references in the generated Word documents?
Example: In the use case chapter the linked requirements are listed for each use case. I would like to have cross-references to the requirements in this document (click on the linked requirement in the use case section - jump to this requirement in the same document).
Any help would be highly appreciated.
BR,
Andreas
Dermot
Re: Generate DOCX with cross-references
« Reply #1 on: August 18, 2016, 04:13:53 pm »
With the report templates in the: Element  | Connector | Source/Target | Element - section there is the option to select the Hyperlink field. Try using that.
andresch
« Reply #2 on: August 19, 2016, 12:30:48 am »
I see, thank you.
Better than nothing, but the problem with these hyperlinks is that you jump to the end of the chapter (not to the location of the actual heading - the start of the chapter).
