Author Topic: Label Rotation lost in shapescript  (Read 9710 times)
« on: August 19, 2016, 05:10:52 pm »
If you have a relationship that displays labels, if there is no override in the shapescript (see below) then you will have the "Label Rotation>" menu item for the label.  However, if you use the label <label name> functionality, that menu item is no longer available.
label middlebottomlabel
print("");
label middletoplabel
print("#Name#");
shape source
shape target
Uncommenting the shape middletoplabel code above will indicate the problem.
We see no reason why there should be such a loss of functionality.
Reported,
Re: Label Rotation lost in shapescript
« Reply #1 on: August 29, 2016, 10:11:55 am »
I have received a response from Sparx indicating that label rotation is NOT supported for shape-scripted labels.  Their argument is that there may be any sort of code behind the shapescript label code and so it's too dangerous.
My counter-argument is that whatever the code, the end result is a text label value (or null - in which case no issue) which is what is being rotated.  I can't see any effective difference between a text label that has 1000 lines of code behind it to generate a value and a text label with no lines of code behind it generating a (the same?) value.
I've asked Sparx to respond with what kinds of code (behind) might inhibit the use of the rotation functionality, but so far no answer.
Thoughts?
« Reply #2 on: August 29, 2016, 11:20:10 am »
Where did you get that from?
ellipse(50,50,100,100);
print("#Name#");
« Reply #3 on: August 29, 2016, 05:06:52 pm »
print("#Name#");
My bad,  I obviously thought that a label section (as opposed to a shape section) produced only a label - otherwise you'd (or I would) have used shape middletoplabel!
Since you CAN use: shape middletoplabel and it works fine...
I recognised that shape middletoplabel is more complex (since it would produce a shape) and would therefore not be amenable to rotation.  I didn't realise that label middletoplabel is just a spurious difference.
So why add the extra keyword when it doesn't mean what it says.
« Reply #4 on: August 30, 2016, 09:00:10 am »
I can only hypothesize that the original author of the shape scripts had something else in mind for them.
« Reply #5 on: August 30, 2016, 09:34:56 am »
But are you saying (even by implication) that label XXXX and shape XXXX will execute the SAME code?
« Reply #6 on: August 30, 2016, 10:23:00 am »
I know of one difference. The labels still have the resize behavior (automatically sizing to contained text) as base labels.
« Reply #7 on: August 30, 2016, 11:45:10 am »
Unclear what you mean here.
Are you saying that: label XXXX has resize but shape XXXX does not?  Or did you mean the base labels without a shapescript?
« Reply #8 on: August 30, 2016, 02:21:14 pm »
If I use the exact script I previously gave you, resizing the label will result in it snapping back to the size of the text. That won't happen if you put the exact same thing in a shape main.
« Reply #9 on: August 30, 2016, 04:15:18 pm »
Thanks...
