Author Topic: Error importing elements from a Word document into EA as a model  (Read 4277 times)
rbmb
I successfully created a custom profile according to sample document I wanted to import into EA using the MDG add-in to import Word documents. While importing; I could see the preview of the EA Model (as it would look after the import); however; on clicking the "Import" button, the plug-in processes all the elements in the Word document but also fails every element and the system hangs - so the document is not imported.
Note: In the "Importing Document" window; the "Abort" button is highlighted after all elements have failed and the system hangs.
Please can someone who has encountered a similar problem suggest the solution? Possibly the Tech support team can post a FAQ or troubleshooting tips to resolve the issue?
Thanks in advance for your help.
RoyC
  • Read The Help!
Re: Error importing elements from a Word document into EA as a model
« Reply #1 on: August 25, 2016, 11:25:38 am »
This is a users forum.
The other users on the forum might well suggest some solutions, but to address Sparx Technical Support directly (and get a response from them) you must send in either a bug report (use the link in the Support column at the foot of this page) or an email to [email protected].
Best Regards, Roy
rbmb
« Reply #2 on: August 25, 2016, 05:19:20 pm »
Thanks for the tip Roy, have done that as well (email to support team).
Best regards,
Rajiv
