Author Topic: Set Page size in a Documentation Template  (Read 7896 times)
philchudley
« on: August 25, 2016, 07:16:48 pm »
Hi
This is a basic question and I should know the answer, but what I try does not appear to work.
Question : How do you set the page size for a Documentation template to be A3?
I have tried Using the Document Ribbon / Edit / File / Printer Setup, but the document still prints A4.
Cannot find anywhere else to set the page size for the Template.
Using EA version 13 beta
Cheers
Phil
Models are great!
Glassboy
Re: Set Page size in a Documentation Template
« Reply #1 on: August 26, 2016, 07:45:59 am »
Do your page boundary markers expand to A3 when you do that?  If they do generate a PDF and see if it is also A3.  If it is your problem is in the the printer driver - printer tray config area.
philchudley
« Reply #2 on: August 26, 2016, 06:18:37 pm »
Thanks for your reply
I have found the solution
Using EA version 13 Beta to set the page size:
Use the Document | Edit Ribbon
Select Edit followed by Edit section...
Complete the dialogue for page settings for this template (or section within template)
Using this it should be possible to use mixed paged sizes with a template and within a document (using master and model documents) although I have not tried this.
Cheers
Phil
Models are great!
