Author Topic: How do I run Nunit Tests I imported via Reverse Engineering  (Read 4330 times)
Eric Beser
« on: August 26, 2016, 09:46:42 am »
I have a set of Nunit tests i created in MSTest to run against our API.  I imported them into my EA model  as part of my general systems model.  I need to run them in EA to generate test results and activity charts against the actual code in my larger system.  I am documenting the entire system's behavior through interaction charts on each API call.
I read the code in, and the code is visible in my system.  Where do i start in executing my Nunit tests?  I am a little lost here.  I had been debugging using the web page and attaching to my project, but these are stand alone tests.
I need a bit of guidance here?  Also best practice?
