Author Topic: DiagramObject.TextAlign  (Read 4843 times)
« on: August 27, 2016, 11:20:20 pm »
The help says
Indicates the alignment of text on a Note element on the diagram.
     1 = Left aligned
     2 = Center aligned
     3 = Right aligned
Defaults to 1 if an invalid value is supplied.
But it always returns 1 and can't be altered. Further: where could that be done with the GUI?
Re: DiagramObject.TextAlign
« Reply #1 on: August 29, 2016, 09:42:59 am »
It reports the wrong value but setting it should work OK.
« Reply #2 on: August 29, 2016, 07:09:36 pm »
Ehrm, what? It reports the wrong value? What should be the right one? The text looks left aligned to me. And I wouldn't know how to set a different alignment with the GUI. So what does this API method do?
« Reply #3 on: August 30, 2016, 08:54:52 am »
TextAlign options are available from the Appearance section of the context menu for Text elements. (Not Note elements)
However, I can only get it to read as left or right aligned, and I can only set it to left or center aligned.
while(i < selectedObjects.Count)
var obj as EA.DiagramObject;
obj = selectedObjects.GetAt(i++);
Session.Output("Alignment: " + obj.TextAlign);
obj.TextAlign = obj.TextAlign%3+1;
obj.Update();
« Reply #4 on: August 30, 2016, 07:22:11 pm »
I have the same observation: can be set correctly but center is reported wrongly. I guess you will log a bug internally. Could you also ask Roy to add a short sentence that this applies to Text elements?
Did you have a look into the other Show-methods which I posted?
