Author Topic: Specification Manager  (Read 14814 times)
Amy_N
« on: September 02, 2016, 04:33:00 pm »
Does anyone know if there's a way to have tagged values as column titles in the Specification Manager?
« Last Edit: September 02, 2016, 04:59:37 pm by Amy_N »
Amy_N
Re: Specification Manager
« Reply #1 on: September 02, 2016, 05:00:38 pm »
Just had a colleague look at this and he has version 12.1 and can do it (I am using 12.0). Next question can you save the specification manager view as a diagram?
Sunshine
  • Its the results that count
« Reply #2 on: September 04, 2016, 06:44:16 am »
No but check out the following
a) model views in the dashboard diagram although the items in the list will be read only.
b) view all items on diagram and view diagram as list - no tag values though.
Happy to help
philchudley
« Reply #3 on: September 06, 2016, 10:21:11 pm »
Hi Amy_N
If you are using EA version 13, then tagged values can be added as follows:
1) Open the specification manager
2) Set the Default Type by choosing the Set Default Type section of the Specification Ribbon
3) Select an element that contains the tagged values within the Project Bowser
4) Right-click the Specification Manager title bar and select Add Tagged Value Column
5) In the resultant dialog ensure the check box Tagged Values from Selected Element is selected
6) Choose you Tagged Value from the drop down list
I would imagine a similar process would work in earlier versions of EA.
Cheers
Phil
Models are great!
Sunshine
« Reply #4 on: September 07, 2016, 07:52:19 am »
Ahh V13 we are all waiting for it with its new UI and features but its taking a bit of time to get out of beta aye?
Happy to help
Helmut Ortmann
« Reply #5 on: September 20, 2016, 02:55:54 pm »
EA 12.1 supports Tagged Values with Specification Manager.
You should ensure:
- No document view!! (simply select another view from Appearance, top right in Specification Manager)
- Define the type of item you want to show (top right in Specification Manager)
I admit, I tried a lot and I got stuck in the Document View.
Kind Regards,
Helmut
