Author Topic: Glossary Tool Tip  (Read 28155 times)
David Rains (bioform)
Re: Glossary Tool Tip
« Reply #15 on: February 16, 2022, 11:33:17 am »
I do have that option on... and checked term is in glossary... e.g. SBVR and type it into Notes for an Element... automatically underlines it SBVR, but no hover text displayed or note text displayed in status line at bottom of widow?
Running version 15.2 BTW.
Have hard rebooted, and turned feature off, exited... turned feature on. exited... Still same response as above... weird.
Found a reference in another thread that if Direct2d is turned off then that might be the reason?
I am experiencing this on my work desktop at home. Will check my laptop and see if that behavior is also there... Will contact our helpdesk and see if they can determine if Direct2D is turned off.
https://sparxsystems.com/forums/smf/index.php/topic,45793.msg268519/topicseen.html#msg268519
"Eve: From memory when looking into similar reports, it can happen if Direct2D is disabled on your system."
« Last Edit: February 16, 2022, 11:43:15 am by David Rains (bioform) »
