Author Topic: DBMS based Project Transfer for 12.1  (Read 10197 times)
bockfu
« on: September 07, 2016, 06:49:31 am »
I am using EA 12.1.1230 with SQL DBMS as repo.
I want to transfer to another SQL DBMS instance.
The Team Modeling Resources for Enterprise Architect page at http://www.sparxsystems.com/resources/corporate/index.html only provides links for 13.0 schema:
http://www.sparxsystems.com/downloads/corp/scripts/EASchema_1220_SQLServer.sql
I created database with scripts cited above.
When transferring form DBMS to DBMS, I get errors comparable to "Cannot find the object "t_category" because it does not exist or you do not have permissions."
When I run the 'Project Compare...' option, unexpected differences are cited.
Are there 12.1 EASchema scripts I should be using instead of those based on 13.0?   If so, where/how do I get them?
Re: DBMS based Project Transfer for 12.1
« Reply #1 on: September 07, 2016, 07:33:57 am »
I guess this schema is still valid and it contains the table t_category. So most likely you see a permission problem. Try a user with full permissions first (grant RWUD is enough though).
« Reply #2 on: September 07, 2016, 08:17:00 am »
The schemas listed on the website are fully compatible with 12.1.
SQL Server requires an additional permission to perform a database transfer. I can't remember what the permission is called, only that it is needed for resetting the auto-number columns.
bockfu
« Reply #3 on: September 07, 2016, 08:38:47 am »
@Simon
SQL has the following 'Fixed-Database Roles':  https://msdn.microsoft.com/en-us/library/ms189121.aspx
Any one of those ring a bell?
I have db_datareader and db_datawriter.
« Reply #4 on: September 07, 2016, 08:54:50 am »
db_ddladmin sounds like the only one that would fit.
« Reply #5 on: September 07, 2016, 12:47:41 pm »
I can confirm that, something to do with the ability to "drop or truncate" stuff I think, but I never got to the bottom of it.
Of course db_admin always works as well. :)
bockfu
« Reply #6 on: September 08, 2016, 06:32:41 am »
double confirmation complete.
Once db_ddladmin role was added I was able to transition SQL based DBMS with no errors or differences to original DBMS.
Thank you,
-Steven
